automaitic using the overdrive
Old Oct 25, 2004 | 11:13 AM
Choppa's Avatar
Choppa
Default automaitic using the overdrive
why is it that when you switch the overdrive off going fast a cloud of black smoke and **** flies out of the exhaust my frineds v6 99 mustang did it once and yesterday a v6 97 mustang did it as the gurl did a fly by
Old Oct 25, 2004 | 11:35 AM
Redline03GT's Avatar
Redline03GT
Default RE: automaitic using the overdrive
Dunno, but he should be drivin a stick anyways!!! J/K it could be because overdrive supposedly gets better gas mileage, and when you switch it off, fuel is burned at its normal rate and therefore you get the cloud of black smoke. It also could be a problem, so hopefully someone will know...
Old Oct 25, 2004 | 05:18 PM
roundman's Avatar
roundman
when you shift out of overdrive at higher speeds, the engine rpm jumps up as the engine is acting like a brake since it was running slower in OD than it would be for the same road speed in 1:1 drive, so this makes the engine "cough" up some smoke just like jerking it from 3rd down to 2nd would do with lots of gas pedal applied.
Old Oct 25, 2004 | 09:17 PM
vfast's Avatar
vfast
I ♥ Acer
it's that split sec to 'puter tries to compensate for a non driver for fuel thus the black some....
roundman..we need to open up a shop for all these kids doing dumbass stuff*L*
Old Oct 26, 2004 | 01:03 PM
roundman's Avatar
roundman
ORIGINAL: vfast
yeah, there sure would be plenty of business, too much for just the two of us to keep up with that's for sure!
CarrieS
Sep 1, 2015 01:00 PM
erig94gt
Jun 11, 2005 03:14 AM
BlackGT5.0
Feb 15, 2005 01:05 AM
89stanglx
Feb 3, 2005 11:17 PM
88_5.0
Dec 24, 2004 04:17 AM
