Help...I am clueless
Old Mar 2, 2007 | 02:21 PM
rebellaire05's Avatar
rebellaire05
Default Help...I am clueless
1996 Ford Mustang, 6 Cylinder
Okay so a couple of days ago, my radiator hose went out in the parking lot of my school. I parked and have not moved it since. I replaced the hose and started it up to see if it was working when Anti-Freeze started spewing out from beneath where the hose plugs into the engine. That night I got a friend to come look at it with me....We started it up and reved it a bit and white smoke was coming out of the tailpipe, with lil droplets of what looked like water? Then he opened where the antifreeze goes and said he saw oil in there.....I checked it today and there is no oil in there. My oil on the dipstick isnt white or off white milky or anything. I just wanna know what the problem is and usually about how much parts are....and labor.....but mainly the parts.
Thanks,
Bo
Old Mar 2, 2007 | 02:25 PM
GreyStang's Avatar
GreyStang
Default RE: Help...I am clueless
Is it the upper rad hose? Maybe your thermostat housing (the spot the hose attaches to) is cracked or broken.. or you didn't clamp the hose down tight enough..
What happened to your original hose? Did it split in the middle or did it also break near the engine side?
Old Mar 2, 2007 | 02:28 PM
HMUSN's Avatar
HMUSN
add more antifreeze.. white smoke means that it is still low or your head gasket is shot.. you didn't let it over heat did you?
rebellaire05
It was the upper rad hose. And it broke near the engine. I am pretty sure everything is clamped on correctly.
Old Mar 2, 2007 | 02:58 PM
GreyStang's Avatar
GreyStang
You need to recheck the thermostat housing for cracks etc.. Top up your antifreeze & verify your oil level hasn't dropped noticably.. did you overheat the engine?
Old Mar 2, 2007 | 03:11 PM
rebellaire05
i dont thinnk it overheated....there was some whit smoke coming from the engine when the hose broke but i assumed it was the antifreeze getting on the engine
Old Mar 2, 2007 | 03:21 PM
TwotoneVert's Avatar
TwotoneVert
You should not have smoke from the hose breakage, sounds like you have more serious problems. HMUSN was correct, if you have water in the oil or oil in your water, you may have blown gasket. Check everything over and make sure you dont have any more leaks. Was it smoking before you had the hose failure?
Old Mar 2, 2007 | 07:16 PM
blacksheeps11's Avatar
blacksheeps11
If you've got oil in your radiator or overflow resevoir, it would sound like a blown head gasket to me.
Old Mar 3, 2007 | 04:33 AM
ryder777's Avatar
ryder777
It is a good prabability that the hose broke due to engine compression in the cooling system. If there is oil in the radiator do not run it at all!! It is important that you may only need a head gasket now but you could really cause yourself some real problems.
Old Mar 3, 2007 | 05:01 PM
Li0nHart's Avatar
Li0nHart
wouldn't it have to more than just a head gasket to get oil in the antifreeze?...i'm thinking a cracked head.pumped your coolingsystem to to like 130psi and blew out your rad hose.
8lug
Sep 21, 2015 01:33 PM
timeformiller44
Aug 26, 2015 12:03 PM
03sonicgt
14
Jan 19, 2006 08:08 PM
dilkaraja14
Oct 7, 2005 12:39 AM
Jimmytz
Jun 28, 2005 12:15 AM
