PIng
Old Mar 4, 2007 | 12:35 AM
Nittro22's Avatar
Nittro22
Default PIng
My car has been pining really bad between 1000 and 2000rpms. I have an SCT Flash tuner which was used to tune the car. how should the timing be adjusted to get rid of the ping.
Old Mar 4, 2007 | 04:48 PM
Chopper's Avatar
Chopper
Default RE: PIng
Reduce the amount of timing advance to eliminate "ping".
Old Mar 4, 2007 | 05:41 PM
GreyStang's Avatar
GreyStang
Default RE: PIng
..or use higher octane fuel
Old Mar 4, 2007 | 11:37 PM
Nittro22's Avatar
Nittro22
Default RE: PIng
i am already using 93 octane, so i will try and retard the timing some
Old Mar 5, 2007 | 06:27 AM
Chitown racer's Avatar
Chitown racer
Default RE: PIng
The flash tuner should have 3 RPM ranges for setting your timing. Simply retard your timing 2 degrees at a time, in the lowest range setting, until it stops pinging.
Old Mar 5, 2007 | 02:02 PM
GreyStang's Avatar
GreyStang
Default RE: PIng
& do it quickly. Ping will kill an engine in no time! Sometimes eccessive carbon deposits in the combustion chamber can also lead to ping in an engine that otherwise would work ok. The carbon deposits can form a hotspot that can pre-detonate the fuel air mixture.
col2560
Dec 11, 2015 10:18 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
95_GT_Stang
Jun 10, 2005 09:36 AM
edjuk8r
Jun 7, 2005 09:17 AM
GT1999
17
Mar 24, 2005 04:18 PM
