no start when hot
Old Mar 4, 2007 | 04:54 PM
malibu kid's Avatar
malibu kid
Default no start when hot
I have a 86 GT when the car get to normal oprating temp.and you shut it off the car wont star up it has to cool for at lest 20 minutes then it starts up when you try to star it sounds like a dead battery .
Old Mar 4, 2007 | 06:23 PM
PONY GUY's Avatar
PONY GUY
Default RE: no start when hot
do u have headers ??? The heat form them could be affeting you starter . I use to have a s-10 blazere with a SBC in it and I had the same problem till i got a mini starter and one of those heat shilds they sell in jegs
Old Mar 7, 2007 | 06:07 PM
p1bigun's Avatar
p1bigun
could be the heat or it could be your timing is to high retard your timing or better yet set it with a light
Old Mar 7, 2007 | 09:19 PM
92cobra's Avatar
92cobra
if you have a tfi module on your distributor im assuming thats what it is. Alot of people have had this problem with tfi modules. Its simple and cheap to replace.
Old Mar 8, 2007 | 10:27 PM
22kart22's Avatar
22kart22
+2
Old Mar 13, 2007 | 09:57 AM
malibu kid's Avatar
malibu kid
change the tfi module the car still doesnt star when hot
thanks for you input
Old Mar 19, 2007 | 12:30 AM
kenv's Avatar
kenv
Could be vapor lock. See if it is running lean
Old Mar 21, 2007 | 10:24 PM
00perfredgt's Avatar
00perfredgt
Check all your electrical connections to the starter, etc. Sometimes the heat will make a bad connection expand and get worse. Happened to me once. Good luck.
bjdutch2005
Mar 24, 2017 03:38 AM
2007StangV6
Jan 28, 2016 06:09 PM
StalkerGT
Sep 25, 2015 02:41 PM
vintageaion
Sep 8, 2015 10:45 AM
5.0 kevo
Sep 3, 2015 06:24 PM
