4.30 Gears just put on
Old Nov 15, 2004 | 06:24 PM
  #41
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: 4.30 Gears just put on
Wow... maybe I wont buy through these guys after all. The Hypertech is like $400 even and the Superchips cost like $480 before the 10% off. Thats crazy. Whats that number again? LOL
Old Nov 15, 2004 | 06:30 PM
  #42
yoshis99_cobra's Avatar
yoshis99_cobra
Okay that's funny. Not really, but it's ridiculous that they want to charge that much.
Nick Holm
319 346 9844
Pro Street Tuning
Old Nov 15, 2004 | 06:34 PM
  #43
jdaniel's Avatar
jdaniel
I ♥ Acer
What are all the options that this tuner gives you? Did you feel much of a gain???
Old Nov 15, 2004 | 06:42 PM
  #44
yoshis99_cobra
I don't know if I can honestly say that I felt a gain cuz I got the gears on and didnt want to start racking up the miles so I isntalled the tuner to make the adjustment for the gears. But a combo with the gears and the tuner really did make a difference. To find out really what all of a difference it can make I suggest going to Diablosport.com, but I'm sure you've already been there. Sorry I can't be more help than that, but I hope to keep getting more answers to my questions.
Old Nov 15, 2004 | 06:45 PM
  #45
jdaniel's Avatar
jdaniel
I ♥ Acer
So you havent used it to do anything else besides the gear recal?
Old Nov 15, 2004 | 06:49 PM
  #46
jdaniel's Avatar
jdaniel
I ♥ Acer
Here is what all it does...
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
On/Off switch for Traction Control
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
WOT Shift Pressure
Part throttle shift firmness
RPM Shift Points
Torque Modulation (for better shift feel)
Cooling Fan ON/OFF Temperatures
Rear Oxygen sensor disable (use for off-road vehicles only)
Disable EGR (use for off-road vehicles only)
All of these parameters can be adjusted on the DiabloSport tune and/or the factory tune
I need to get one. LOL
Old Nov 15, 2004 | 06:52 PM
  #47
yoshis99_cobra
I ran the Diablo tune along with the racalibration. But really other than that no. I just did it on Saturday. I'm looking to advance the timing, but some are saying that you can only go either 2 up or 2 down on the tune. I want to find more info about this first. I also have an email to someone from DiabloSport to help me out with this and another issue that I have with it. You have an option to turn the traction controll off upon startup, but after doing that I can't enable it again unless I run thru the tune again. I was wondering if this was a mistake or if it's something that just disables the traction control and that's it. If so, i don't like that. I want to be able to turn it on if I run into rain or I get stuck outside while it starts to snow. I hope I don't ever get stuck in the snow, but when I do every little bit of traction helps I would imagine.
Old Nov 15, 2004 | 06:55 PM
  #48
jdaniel's Avatar
jdaniel
I ♥ Acer
I think MD said once its off then its off for good that it cant be turned back on. Im not to sure though. If I had the chance to turn mine off I definetly would. I turn it off everytime I get in anyways.
Old Nov 16, 2004 | 10:40 PM
  #49
BlackMage's Avatar
BlackMage
hey guys, i read all ur posts with the 4.30 gears in your 99, in a 98 will i notice the same differnce u think? t-45 tranny mind u and it is a gt
Old Nov 16, 2004 | 11:27 PM
  #50
jdaniel's Avatar
jdaniel
I ♥ Acer
Dont quote me on this but I think someone said the most you wanna go with on the T5 or the T45 is 3.73's. I dunno though.
musnicki
Sep 23, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Sep 3, 2015 07:14 PM
