Transgo kit
Old Nov 18, 2004 | 01:35 AM
Valek's Avatar
Valek
Default Transgo kit
Anybody with some info about transgo. What's in the shift kit how do you install it.
Old Nov 18, 2004 | 02:26 AM
Quik's Avatar
Quik
Default RE: Transgo kit
yea i did it to my 88. easy but time consuming. great kit. youll have your choice of race springs or street ones. iwent race and it does shift hard and late. plus my OD is now 4th gear
Old Nov 18, 2004 | 02:35 AM
Valek's Avatar
Valek
So... you can do the same thing with a tuner or not
Old Nov 18, 2004 | 03:26 AM
Quik's Avatar
Quik
you can but its not as fool proof as a valve body setup. computer can slip up and cause issues. for the 110 bucks for the kit. its worth it. while your at it do all the servos you can to hlep out also. then dont touch the tuner for the tranny
ORIGINAL: Valek
Old Nov 18, 2004 | 09:01 AM
rebelrexx's Avatar
rebelrexx
agree with osh, but watch out what you do, harder shifting tranny's acctually last longer, less slip, definetly the way to go, its a simple do it your self project, just pay attention to check *****, and personally i wouldn't mess with the servos, they are a definite pain in the ***
Old Nov 18, 2004 | 12:51 PM
Quik's Avatar
Quik
i know on the Gm trannys the stock servos are junk and should be replaced. i dunno about the ford ones but if one company are junk the other one must be along the ways
ORIGINAL: rebelrexx
Old Nov 19, 2004 | 12:01 AM
Dan04COBRA's Avatar
Dan04COBRA
GM servo's aren't just, just nothing impressive.
Also, if your going to be doing work on your automatic, the best thing you can do is install a cooler somewhere. It'll prolong the life and keep the shifts firm forever.
Old Nov 20, 2004 | 08:40 AM
rebelrexx's Avatar
rebelrexx
its easy and it won't slip, quality stuff, just make sure you get some transgel or vaseline to make quick ease of the check *****, DO NOT DROP THEM, they are extremely hard to chase, and personal knowledge not a lot is to be gained by changing servos, all they do is cushion the apply some using a spring, its pretty easy to just change spring rate on them, but its just still a harder shifting tranny's, and as far as gm stuff, its all pretty stout, ps you should have a cooler in there already someplace, probably bottom of radiator, or else everyone would burn fluid faster than a butane torch
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
