moisture
Old Apr 16, 2007 | 11:33 PM
00blackstang's Avatar
00blackstang
Default moisture
How would the car run if moisture got into the motor.. and is it possible?
Old Apr 17, 2007 | 12:59 AM
ColdCityMustang's Avatar
ColdCityMustang
Default RE: moisture
Very possible,
Coolant could leak through a worn head gasket, or possibly seep through a crak in the head itself. Water could come in through the air cleaner(little tougher to get this to happen, but I've seen it). Water could get into the gas tank, and if you haven't been keeping up on fuel filters and what not, the water has an open door through the injectors. The car wouldn't run the same if it had moisture in it. It would all depend on the amount of moisture, you probly wouldn't notice it if it was a small amount. If you have moisture in your engine, the car will probably be blowin white smoke(steam) out the exhaust even after the car is warmed up. Yeah thats about all I got on the topic...anything else?
Old Apr 17, 2007 | 01:01 AM
ponysnake99's Avatar
ponysnake99
too much moisture and you hydrolock and your engine doesn't run period...your car also generates a small amount of condensation around start up...easily burned off by the oil and such
Old Apr 17, 2007 | 09:43 AM
GreyStang's Avatar
GreyStang
What do you mean by "moisture on the engine"?? Did it rain on the engine with the hood off? Did the car go for an unexpected swim?
Old Apr 17, 2007 | 02:02 PM
00blackstang
no just we had that nor easter, and no the cars runnin like **** and i dotn no y
Old Apr 17, 2007 | 02:23 PM
ponysnake99
care to give the symptoms? we might be able to pinpoint it a little easier that way
Old Apr 17, 2007 | 09:14 PM
corvetteguy's Avatar
corvetteguy
Every car runs with moisture every time you
start it. before it warms up the moisture is
presaent in the oil. When the car reaches temp the
moisture burns off. This is easilly demonstrated on
my 38 ford tractor which I have removed the thermostat.
It never overheats or fully warms up so the oil starts to
turn milky and looks like froth on the oil filler tube.
If your cars oil looks like that you have a problem, in
a tractor it is ok but not in a mustang.
4cylinderplus2
Oct 9, 2020 07:45 PM
65coupe88hatch
Nov 22, 2006 01:08 PM
mightyb28
May 31, 2006 09:43 PM
razarr69
Oct 15, 2005 03:41 AM
rockin95
Sep 26, 2005 02:07 AM
