Lifters
Old Apr 17, 2007 | 07:08 PM
evil351's Avatar
evil351
Default Lifters
Need help from the pros....
Does the Intake manifold needs to be removed to pull out a lifter?
Please Advice
Thanks
Evil351
Old Apr 17, 2007 | 07:48 PM
tokinGLX's Avatar
tokinGLX
duke of herb
Default RE: Lifters
yes it does
Old Apr 17, 2007 | 09:07 PM
evil351's Avatar
evil351
Default RE: Lifters
Thank you Tokin....
When I removed my valve covers to replace a broken roker arm, I tryed to torque another that was loose but nothing happend, Ias told that it might be a "collaps lifter".... , what do you think?
Thanks again
Evil351
Old Apr 17, 2007 | 10:38 PM
tokinGLX's Avatar
tokinGLX
duke of herb
Default RE: Lifters
well, im no mechanic myself, but rocker arm is connected to the pushrod which sits right on the lifter, which rolls(assuming its a roller cam) over the cam.
something along that path is fuggered up.
Old Apr 18, 2007 | 02:02 PM
evil351's Avatar
evil351
Default RE: Lifters
Gracias, Tokin
Old Apr 21, 2007 | 09:35 PM
67mustang302's Avatar
67mustang302
Default RE: Lifters
First of all, what kind of cam is it? Roller, flat, hydraulic, solid? And is it making any noises? I recently pulled a valve cover cuz of a NASTY noise I developed, turns out the needle bearing in the roller on no1 exhaust lifter grenaded. Also, pull the pushrod from the loose rocker and see if it's straight. Easy was is to roll it across a smooth surface, like an even metal table and listen and look for wobbling as it rolls.
WDScott
Aug 17, 2015 06:38 AM
ding56
Aug 14, 2015 02:40 AM
Stinger
Mar 28, 2004 09:06 PM
fasteddie
Mar 1, 2004 04:45 AM
w11988
Dec 9, 2003 06:41 PM
