HELP!!! problem with 5.0 motor!!
Old Apr 19, 2007 | 03:38 PM
xnext's Avatar
xnext
Default HELP!!! problem with 5.0 motor!!
i have rebuild the motor on my mustang it has erything new but the lifters are sounding bad and there almost no oil coming into the heads and the oil presure is up!!, its a new oil pump! new cam shaft! new lifters and it stil souds bad!! what can i do!!!
Old Apr 19, 2007 | 03:39 PM
P Zero's Avatar
P Zero
Default RE: HELP!!! problem with 5.0 motor!!
Check to make sure you didnt snap your oil pump driveshaft. Pull out your disty and its right under there.
-P.
Old Apr 20, 2007 | 03:57 AM
kev2369's Avatar
kev2369
You soak your lifters before you put them in?????? I'm gonna guess no, if not, they probably aren't built up and thats more than likely where you're noise is coming from....
Cannibal_carnies
Mar 2, 2023 06:17 PM
Stilz
Aug 18, 2015 09:40 AM
05slpGT
Aug 12, 2015 02:32 PM
daytooday
Aug 11, 2015 09:22 AM
Pain.
Aug 7, 2015 10:48 PM
