A/C Problems, need pointers
Old Apr 21, 2007 | 12:16 AM
txjason1's Avatar
txjason1
Default A/C Problems, need pointers
1995 Mustang GTS 5.0 HO.
How much voltage should I see on the connector at the A/C Compressor.
Summer coming need A/C in the South.
Fuses all good. only 290mv at the compressor. any ideas where to start?
Thanks a MILLION!
Old Apr 21, 2007 | 02:33 PM
Rebornmust_owner's Avatar
Rebornmust_owner
Default RE: A/C Problems, need pointers
You should be able to jump the 2 wires at the accumulator and the clutch on the compressor will engage. If that doesn't happen you may have an issue with either the Wide Open Throttle Relay being stuck, or a TP sensor showing the PCM that you are at wide open throttle or the head unit has an issue. Also make sure you have enough freon in the system to make things happen. The only way you are going to know that is to hook up gauges and check pressure because the system will seem to have pressure in it but no freon.
Old Apr 22, 2007 | 05:33 PM
txjason1's Avatar
txjason1
Hey reborn, I already jumpered the Compressor. It will engage and run. The low pressure side the hoses arent cold but just normal temp, the high pressure side is hot. I think that it may need a flush and recharge. Os there a switch or something that is telling the system the pressure is to low, and not to run? I am trying to trouble shoot it before I take it in to be serviced, to try to avoid a huge bill! I already have replaced the vacuum swith in the dash (was bad) and found 3 vacuum leaks and repaired them aswell. there is pressure in the system. so at least its not dry. The compressor was replaced back last year (previous owner) but they didnt replace the dryer.
Thanks for the help so far!!! I can do all the mods you can think of, but last hotrod I had first thing I did was rip out the A/C......LOL now as I get older.....I want NEED the A/C.
Thanks again Jason
Old Apr 22, 2007 | 07:29 PM
Rebornmust_owner
You should have a high and low side switch but they rarely go bad. If the previous owner had to replace the compressor then the fixed orifice tube also should have been replaced. The tube is a filter but the only way to replace it is to evac the whole system down, replace or clean it, install new o rings and recharge. The filter has to be replaced as part of a new compressor and should be cleaned everytime you vac the system down. You should have 12 volts at the comp. clutch when ever the system is engaged.
What kinda car is it?
Old Apr 23, 2007 | 11:30 AM
txjason1's Avatar
txjason1
1995 GTS Mustang last of the 5.0L H.O.'s as of this moment, I have NOTHING at the comressor. (on teh plug) 200mv if that. so there are no check valves or protection circuits that keep teh compressor from running if pressure is to low? I am good to teh relay....I will check again when I get released 1700 formation (army guy). Man thanks again for all the help.
Jason
vargas
Jun 17, 2017 12:17 PM
ChampInSD
Oct 2, 2015 04:55 AM
stangin1996gt
Sep 21, 2015 11:01 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
