clutch starting issue help!!!
Old Dec 7, 2004 | 11:59 PM
fordcarrs's Avatar
fordcarrs
Default clutch starting issue help!!!
I have a 94 gt with a 347 stroker, MY first issue is that i can start my car without pushing down the clutch. Ford can't help, go figure, I have removed the clutch position sensor and I can still start the car. The only other thing is that one day the care would not start, I followed the starter wire(tan / pink) up to the fuse box are, disconnected it and put power right to it going down to the starter, it cranked. From then on I can start it with out pushing down the cluch pedal. Help any suggestions.
Old Dec 8, 2004 | 12:23 AM
89stanglx's Avatar
89stanglx
Default RE: clutch starting issue help!!!
Old Dec 8, 2004 | 01:45 AM
Choppa's Avatar
Choppa
so u hot wired your car? that seemed as simple as the movies make it look
Old Dec 8, 2004 | 12:52 PM
roundman's Avatar
roundman
sounds like the neutral safety start switch is bad, replace it and then you will have to be in neutral or push in the clutch to start the car again.
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
MXBT187
Aug 20, 2015 02:36 AM
ponyride00
Aug 12, 2015 01:57 PM
