NEED HELP ASAP
Old May 17, 2007 | 06:03 PM
fast03bra's Avatar
fast03bra
Default NEED HELP ASAP
ok so now my stang (70) won't turn over it will crank but not fire had car running and driving the other day! has new carb fuel pump fuel filter plugs wires cap and rotor starter soleniod anything i am missing?! will fire on for a second on starting fluid help needs to get tagged tomorrow
Old May 18, 2007 | 12:00 AM
NorCalTroy's Avatar
NorCalTroy
Default RE: NEED HELP ASAP
Hi Matt, welcome to Mustang Forums!
I'm guessing if your car fires with starting fluid, but not without, then you are having a fuel delivery problem. Did you make all the above changes at the same time, and did the car run correctly before these changes?
Old May 18, 2007 | 01:12 AM
GreyStang's Avatar
GreyStang
Is fuel making it to the carb? Try starting it with the air filter off,, can you smell gas? When NOT starting the engine look down the carb barrels & open the throttle. Can you see fuel squirting into the venturi?
Old May 18, 2007 | 03:14 AM
fast03bra's Avatar
fast03bra
thanks for the welcome and the help turns out stuff i guess i missed in the gas tank came through made it past the filter and into my carb, i cleaned it and added a inline fitler as well, find out tomorrow if it worked
Nick Oliver
Oct 17, 2018 04:22 AM
DJ Piner
Sep 30, 2015 03:03 PM
fireboss343
Aug 21, 2015 06:25 AM
kirk35
Aug 17, 2015 08:42 PM
MelloYello
Apr 23, 2004 03:59 AM
