Control arm on drivers side moving
Old May 27, 2007 | 07:20 PM
MustangMike2001's Avatar
MustangMike2001
Default Control arm on drivers side moving
I made a post not too long ago about how I was having a loud popping noise everytime I hit my brakes. I finally figured out what it was by getting my girl to pump the brakes and let it move foward a bit while I looked. The control arm on the drivers side is moving back and forth at the point where the two bolts hold it to the sub frame. I had just taken the front suspension off to lower it and it started doing this after I got it all back together. I also replaced the ball joint on that control arm. I'mnot sure if that would have anything to do with it. I have taken the front apart before and replaced the ball jointsand the subframe before after a wreck and I never had this problem afterward. Any ideas as to what is wrong and how to get it fixed?
Old May 27, 2007 | 08:54 PM
89 fox's Avatar
89 fox
Default RE: Control arm on drivers side moving
your control arm bushings are shot....might as well replace em with some poly ones...
Old May 28, 2007 | 01:45 PM
MustangMike2001
Do you think the bad bushings on the drivers side could be the reason my car pulls to the left even after being aligned? Thats been a problem ever since the first time I took the front apart and put that control arm on. It was a junkyard part and I replaced the ball joint on it but I didn't think about the bushings. Any idea how you get the old bushing out? I assume you have to press it out but is there a special tool or anything?
Dragonus18
Sep 9, 2015 01:21 AM
TimeLord101
Sep 4, 2015 09:27 AM
amandahchase
Sep 3, 2015 10:09 AM
