fuel pump kill switch
Old Jan 1, 2005 | 11:05 PM
2001v6IL's Avatar
2001v6IL
Default fuel pump kill switch
Has anyone ever installed a fuel pump kill switch (toggle). I was thinking of doing that over an ignition kill switch, which can easily be bypassed. I have a 2001 mustang v6. This is for security purposes so if anyone jacks the car they wont get very far if the switch is off=no fuel.
Old Jan 1, 2005 | 11:12 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: fuel pump kill switch
I think you can get a chip with a key..for that..
Old Jan 1, 2005 | 11:49 PM
luckythirteen13's Avatar
luckythirteen13
i was just thinking of doing the same thing today.......
Old Jan 2, 2005 | 03:51 AM
2001v6IL's Avatar
2001v6IL
Anyone else done this??? I dont really want to spend the dough on a new chip, kind of excessive.
Old Jan 2, 2005 | 04:47 PM
2001v6IL's Avatar
2001v6IL
Ok this may be a lame question, but does anyone know which wire to cut into to do this? I was just going to follow the wire from the fuel shutoff switch in the trunk back to the fuel pump, and see if i can tell which one is the power wire. Any help appreciated.
Old Jan 2, 2005 | 05:31 PM
11seccobra03's Avatar
11seccobra03
Do u have a aftermarket fuel pump
Old Jan 2, 2005 | 06:30 PM
2001v6IL's Avatar
2001v6IL
no aftermarket fuel pump, car is pretty much stock right now.
Old Jan 2, 2005 | 08:00 PM
e40water's Avatar
e40water
Well I added a kill switch to my key igition on my 83 stang I have a mechanical fuel pump, So there is really no need for me to have a disabler to my fuel, you can add switch valve to you fuel line, Ive seen that work pretty good, they can still start youre car and drive off with small amount of fuel in the line. Usually when a thief is going to steal youre car they usually try to break the key igition slot, Or prying the ingtion switch box on the colum, Ive only seen hot wiring methods done with 60's-70's stang's, Not any with 80's-00's. toggle switches work ok, thieve usually know where to look for them. a good hiding spot would be inside a heater vent.
Good Luck.
Oct 26, 2015 05:01 PM
Meystang
Sep 25, 2015 04:05 PM
pimp2303
Sep 17, 2015 08:45 PM
SteelerNation82
Sep 16, 2015 07:11 AM
rksnow1
Sep 14, 2015 08:46 PM
