head gasket
Old Jun 13, 2007 | 09:47 PM
Scooterman's Avatar
Scooterman
Default head gasket
i just got a question regarding value... my cars got a broken head gasket which i heard is a major job.. my question is... would this change the value of my car if i were to sell it considering it is such a big job
Old Jun 14, 2007 | 01:14 AM
1991LX5.0's Avatar
1991LX5.0
Default RE: head gasket
it definitely will
Old Jun 15, 2007 | 08:17 PM
dadoordude's Avatar
dadoordude
Get a can of Barrs block sealer and follow instructions, this will stop most head gasket leaks for a while until the repair can be done
Old Jun 16, 2007 | 01:45 AM
cottoncandymustang's Avatar
cottoncandymustang
Just repair it man. its really not that tough of a job what year is it? what size motor if its the 5.0 302 cid its really simple brotha well not really simple but dont put that block sealer in it man.. ive torn into alot of motors with that stuff in it and its some nasty S***
Old Jun 17, 2007 | 10:50 PM
dadoordude's Avatar
dadoordude
Kenny a little history on when I used this for a "temporary repair",I have used this several times for a temporary repair when we raced mini stocks back in the late 70s, in between rounds therewas not enough time to pullthe head and replace the gasket, when the repair was done at home there was noproblem with the sealer blocking anything or even slowing the flow of water, it's possible the motors you tore down had a lot more than the recommended amount.
Old Jul 6, 2007 | 12:15 AM
cottoncandymustang
quite possible but i still do not recomend it gaskets are made to be the sealers not other additives. im not trying to disrespect you but i just dont agree with the stuff now if your in a half to use basis like racing like you said yeah then id maybe. just maybe use it but the 350 i tore into at my shop with about 163000 miles on it .. yeah i saw what it did.. clogged the water galleries .. but you could be right it might have been to much the customer put in his motor i just dont fancy that kind of stuff at all
GimpyHSHS
19
Dec 19, 2023 01:12 PM
kevsgt
Oct 9, 2015 10:12 PM
Dathan
Oct 5, 2015 05:52 AM
Drastang
Sep 30, 2015 03:48 AM
wraith777
Sep 28, 2015 10:49 AM
