Keyless entry 99. Repogramming does not work
Old Jul 5, 2007 | 07:01 AM
petter's Avatar
petter
Default Keyless entry 99. Repogramming does not work
My car was delivered without the keyless remote trensmitter so i bought one on Ebay
Tried several times with the instructions on programming keyless remote entry (ignition off to on 8 times and so on...)
The doors does not lock/unlock as described in the instructions. Anyone else had that problem? Solution?
Does all 99 GT:s have the keyless remotebuilt inor is it an option maybe?
Thanks
Petter
Old Jul 9, 2007 | 01:13 PM
rogerwilco357's Avatar
rogerwilco357
Default RE: Keyless entry 99. Repogramming does not work
let me know what you find out as i have a 97 that won't start due to the pats anti theft system and transponders.
Old Jul 9, 2007 | 04:14 PM
molecule's Avatar
molecule
A lot of strange things can sometimes be solved by disconnecting the battery for 20 minutes or so and then re-connect and take another whack at it.
Old Jul 9, 2007 | 05:11 PM
89 fox's Avatar
89 fox
we just went through the same thing at the shop last week...we changed a lock cylinder on a ford tarus...we had to use a ford scan tool to reflash the PAT system.
Old Jul 11, 2007 | 01:54 PM
samoyed's Avatar
samoyed
ORIGINAL: petter
Thanks
Petter
you have to short out the 2 wire studs in the left side of thetrunk- just did it on my 97 v6 and all works fine.
looking for the site now will ost back.
Old Jul 11, 2007 | 01:56 PM
samoyed's Avatar
samoyed
Code:
http://www.programyourremote.com/
here you go.
now can anyone tell me how to turn off the engine warning light-without paying a mechanic 40 bucks.
did it on my 96 Nissan Maxima for free.
Old Jul 18, 2007 | 02:04 PM
petter's Avatar
petter
The "short out the 2 wire..." solution does not work on 99+. Neither did disconnection ofthe battery.
Thank you Samoyed but thats the original solution and does not work.
Theproblem may occured when i removed the lock cylinder (you are not allowed to have blinkers and brake lights in the same bulb in Europe. ) I did cut the green wire and put the cylinder back again.
Comments?
Thanks anyway
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
