pulley puller
Old Jul 7, 2007 | 07:45 PM
347stang's Avatar
347stang
Default pulley puller
I am switching my 14lb pulley to the stock 3.33" pulley on my vortech s trim. I have heard that checker/autozone will let you use their puller for free. Does anyone know if this is true or should I order my own?
Old Jul 7, 2007 | 07:58 PM
ALMOST STOCK's Avatar
ALMOST STOCK
Default RE: pulley puller
I've rented tools from autozone before.
You'll need to leave them a deposit (usually it'sthe cost of the tool) you'll get your deposit back once you've returned the tool, or that's how it works at the autozone near me.
Old Jul 7, 2007 | 09:09 PM
1991LX5.0's Avatar
1991LX5.0
what i did was just take a torch to the pulley to make it expand then just pull it off by hand. That what you dont mangle the ribs on the pulley
Old Jul 7, 2007 | 10:11 PM
347stang's Avatar
347stang
I dont have a torch though, I have a lighter lol that is about the best I can get. pulling a pulley isnt very hard though is it? Also will I need a different belt? if so how do i know what size crank pulley i have or should i just measure it?
Old Jul 7, 2007 | 10:54 PM
1991LX5.0's Avatar
1991LX5.0
no its not hard at all. basicly it has teeth that hold ont the outside of the pulley then a long bolt that presses on the shaft, as you turn the bolt it presses on the shaft and pulls on the pulley and off it comes. As for belt legnth you probably will need a longer belt, it should just be the stock legnth belt so it shouldnt be too hard finding one
Old Jul 7, 2007 | 11:29 PM
347stang's Avatar
347stang
I found one on the classified section that fits 3.33" pulley and 6.75 inch crank pulley. Would that be the right one? it is only 30obo so I am guessing that isa pretty good deal.
Old Jul 8, 2007 | 01:25 AM
1991LX5.0's Avatar
1991LX5.0
actually i think thats the stock setup for a 6rib set up 3.33/6.87 i think the stock8 rib has an 8in crank pulley
Old Jul 8, 2007 | 01:35 AM
1991LX5.0's Avatar
1991LX5.0
nevermind you were right i have my stock 6 rib crank pulley right next to me and i measured it and its 6in
GimpyHSHS
19
Dec 19, 2023 01:12 PM
spdeplayer2
Oct 24, 2015 09:45 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
ctgreddy
Sep 20, 2015 08:35 PM
