Throttle Body Worth It?
Old Jul 14, 2007 | 01:57 PM
Stang2891's Avatar
Stang2891
Default Throttle Body Worth It?
Hi, I have a '96 mustang gt and I was just wondering if anyone had installed a throttle body on their car, and thought it was actually worth the money. The car only has a few performance mods to it, and I really didn't want to get too crazy with the car, since it is my daily driver, so I was wondering if anyone thought it was a good idea to buy. I also heard that if the motor is stock, you should go with a 70mm throttle body over the 75mm throttle body. Is this true? Any info/advise would be appreciated. Thanks.
Old Jul 14, 2007 | 02:30 PM
Black_GT_02's Avatar
Black_GT_02
Default RE: Throttle Body Worth It?
if you get a 75 instead of a 70....its not going to makea difference
i would just go with the 75 just in case you do decide to start heavily modding your car
Old Jul 14, 2007 | 05:34 PM
Stang2891's Avatar
Stang2891
Ok, thanks. So would I notice a big jump in performance with a 75mm throttle body as opposed to stock?
Old Jul 16, 2007 | 06:40 PM
oachs83's Avatar
oachs83
A TB (throttle body) is just a part of the puzzle. If youjust add a TB and expect wheelies your dreaming. You may notice a small difference but the larger TB's are really made to go with a cold air and bigger intake setup all together. A TB is just allowing more air into the engine wich is good but if you throw a 75mm TB on a stock intake that is at lets say 65mm the end result is 65mm of air getting into the engine only still. You just would have the air getting forced ina little harder.
Old Jul 16, 2007 | 08:52 PM
94Blk5.0's Avatar
94Blk5.0
A 75mm T.B and Plenuem combo was wirth between 17 and 20 HP in a tech dyno trail article on a 2003 GT. The 96 should benefit as well.
Note off caution. After installing diconnect the battery for 30 min to reset ECU. I guy I used to work with had a 97 GT and put a 75mm t.b and plemun, he liked the results, but later installed a catted SLP X-pipe and the check engine light came on. Got some MILS, and light did not go away because it was for improper a/f ratio. It was brought on by the new combo of intake /exhaust work w/o resetting the ECU.
GLOCKer
Sep 28, 2015 07:36 AM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
JDWalton
Sep 24, 2015 08:47 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
