long tubes headers
Old Aug 4, 2007 | 04:32 AM
medic33's Avatar
medic33
Default long tubes headers
can i do it? Got some jackstands, a tool box with wrenches, and and all winter long.Where will my headaches be?What headersdo Iget? And ifI take the correct steps will i still wish i had paid the 8 hours of labor?
Old Aug 4, 2007 | 07:29 AM
Chopper's Avatar
Chopper
Default RE: long tubes headers
Removing the old manifolds is as hard as getting the new parts on.
The best way is to remove the K-member so you can gain easier access to the nuts and bolts that hold the headers to the head.
USE A TORQUE WRENCH TO TIGHTEN THE HEADER BOLTS TO THE HEAD.This way you won't have to post a question about how to find the ticking noise coming from a leaking header gasket.
Old Aug 4, 2007 | 11:35 AM
nitrous_bob's Avatar
nitrous_bob
is it a foxbody ?
it doesn't take that long at all to do long tubes.
there are 2 potential problems you might run into, so be prepared for either.
1) the most probable....the header will bump on the frame rail from the motor mount being old and weak
2) only seen it once on 5 cars (a buddies car not mine) you might need the flaming river steering knuckle to clear the tubes
now i always MAC, my buddy used bbk and had that problem on a '93 cobra, bbk is nicer than mac
while your in there, dump the smog and all the tubing that goes with it, you'll need to plug the back of the heads w/ thermactor plugs, they are a threaded insert like on the front of the heads. you will also need to plug the h-pipe where that y pipe ties into it.
after that you have a lot of room to work on everything
you need to raise the motor to get the lt's on, so you might as well replace the motor mounts w/ a set from a 'vert
pop the tranny out and might as well do a clutch and rear main while your at it.
once the new headers are on, it's easier to r&r the tranny in 2 pieces....first the bellhousing then the trans itself
since the trans will be out, might as well get a new shifter if you don't have one
drain the tranny and refill w/ synthetic atf, easiest way to fill is throught the shifter opening, 2 3/4 qts
Old Aug 8, 2007 | 01:11 AM
medic33's Avatar
medic33
Sorry, forgot it's a 98 GT with the 4.6 dohc.Everybody is telling me i'll have to remove the motor mount bolts,also what is the torgue spec's.
Jb145700
Aug 21, 2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
BrantleyS550
Sep 14, 2015 04:18 PM
