Wheel Weight
Old Aug 4, 2007 | 08:00 PM
TwoToned306's Avatar
TwoToned306
Default Wheel Weight
Does taking weight off the driveline or wheels make more of a difference than taking the same omount off of the car in general?
( As far as track times go)
I want facts, not opinions. I would love to hear from someone who has proven or tested this firsthand.
Thanks, Michael
Old Aug 4, 2007 | 08:55 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: Wheel Weight
yes it does, DS for example = less rotating mass
and an aluminum flywheel will spin quicker, as opposed to hit harder like a steel one.
Old Aug 4, 2007 | 09:23 PM
TwoToned306
Has anyone went from one wheel to a lighter wheel of the same dimensions, and same tire size, was there any noticeble improvements?
Old Aug 6, 2007 | 10:14 AM
TwoToned306
anyone?
Old Aug 6, 2007 | 12:48 PM
Panther_Driver's Avatar
Panther_Driver
Yeah, it's called "unsprung" weight because it's anything that's not supported by the suspension. Wheels, tires, brakes, etc. You probably won't notice a huge difference unless wheels you have now are really heavy. Like nitrous_bob stated, less rotating mass. It takes less energy to rotate lighter wheels, so in essence, you get a little more power to the ground, a little quicker. Plus any less weight on the car is always an improvement. Will it knock off a ton of time in the 1/4? Probably not, but every little bit helps there. And it probably won't be extremely noticeable in a daily driver. On my old car, I upgraded the wheels and shaved off 10 lbs per wheel, and a couple more lbs. on the rubber. She felt a bit more spirited and nimble, but that could have been more placebo than performance. But hey, who needs an excuse to upgrade wheels? :P Might as well go for lighter ones!
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
