Shifting Question
Old Aug 8, 2007 | 08:46 AM
feedingfrenzy's Avatar
feedingfrenzy
Default Shifting Question
Any problems with starting in second and going to forth?
Old Aug 8, 2007 | 08:50 AM
TwotoneVert's Avatar
TwotoneVert
Default RE: Shifting Question
Just being under powered and possibly burning the clutch engaging second depending on how long you take to engage.
Old Aug 9, 2007 | 09:53 PM
88_LX's Avatar
88_LX
you would need atleast 4.10 gears and a lot of money for clutches
Old Aug 9, 2007 | 10:27 PM
94Blk5.0's Avatar
94Blk5.0
If you want to skip gears try:
1--> 3 --> 5 or 1,2,4,5 or 1,3,4,5
I started doing that, because there is no point in hitting every gear in a DD situation. Your Cobra will have plenty of TQ to acclerate at agood pace even when skipping 2&4. I'll shift between 1500 and 1800 RPM's most of the time, and still skip some gears.
Old Aug 10, 2007 | 06:27 PM
945LSTANG's Avatar
945LSTANG
skipping gears is basically worthless. it just takes more thought and concentration. the only way it might work well would be if you had some gears in the rear. i see no problems with it damge wise btw.
Old Aug 10, 2007 | 07:06 PM
Chopper's Avatar
Chopper
Take it easy on your clutch and start off in first.Then skip second and fourth.
Oct 7, 2015 07:02 PM
degner122
Sep 16, 2015 07:09 AM
Mustangmalo
Sep 6, 2015 05:22 PM
