LX 5.0 Starting Issue?
Old Aug 20, 2007 | 02:56 PM
72MACH1_92LX50's Avatar
72MACH1_92LX50
Default LX 5.0 Starting Issue?
I am having the problems with my 92 LX 5.0... Every few start upattemts or so, I will turn the key and nothing will happen, only the dummy lights in the gauge cluster will come on? The batteryand the solinoidare OK. I have been using a wire to jump from my solenoid to my battery's positive terminal to start the car. I used a test light when the problem occurred and there was no current coming from the starter switch to the solinoid. I changed the starter switch and the problem still happens?My last stab is that I have a shorted wire between the starter switch and the solinoid?
What do you all think is the issue here?
Thanks.
Old Aug 20, 2007 | 08:12 PM
P.S.I.cho's Avatar
P.S.I.cho
Default RE: LX 5.0 Starting Issue?
by shorting the solenoid your basically just creating a ground so check all your grounds first it could be something that simple as a loose ground.
Old Aug 24, 2007 | 10:30 AM
72MACH1_92LX50
ORIGINAL: moocow_v
I'm going to check my ground wires... Thanks.
Old Aug 25, 2007 | 08:36 AM
72MACH1_92LX50
ORIGINAL: 72MACH1_92LX50
ORIGINAL: moocow_v
My grounds wires are all OK?
Old Aug 25, 2007 | 01:11 PM
redneck racer's Avatar
redneck racer
could be ignition switch, i just had to change mine because it wouldnt start, the clock and radio worked fine... When i changed it stuff like my windsheild wipers and random stuff worked again... its a cheap and easy fix... might want to try only $10.00 at your local parts place.
Old Aug 26, 2007 | 09:10 PM
72MACH1_92LX50
ORIGINAL: redneck racer
I changed the ignition switch (located on the steering column) already and still have the same problem ???[:@] The trigger wire from the ignition switch to the solenoid does NOT flow current (checked with a test light) when I have the starting problems?
Old Aug 28, 2007 | 05:15 PM
FastFordMustang's Avatar
FastFordMustang
Have you tried jumping from the ignition switch directly to the starter relay with a jumper wire?
You should hear a click at the relay (or the car should start)
Let us know peace
Old Aug 31, 2007 | 07:40 AM
Jfsram's Avatar
Jfsram
If the relay is clicking you can assume the ignition switch and clutch switch are good.
Old Dec 1, 2009 | 06:33 PM
72MACH1_92LX50
fyi, a bad "Park Neutral" safety switch was the problem!
Old Dec 3, 2009 | 09:16 AM
Jfsram's Avatar
Jfsram
Then your relay was not clicking.
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
drfister
May 3, 2018 10:38 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
