Need brake Help !!!
Old Sep 9, 2007 | 09:49 PM
polodude28's Avatar
polodude28
Default Need brake Help !!!
i have an 01 mustang gt bought brakes having problem with the back brakes. problem is that i cant twist the piston back in so i can but the brakes we use clamps to push it in and i didnt work it feels like its suck. if anyone has suggestings please let me know.
thanks,
daniel
Old Sep 10, 2007 | 06:20 AM
corvetteguy's Avatar
corvetteguy
Default RE: Need brake Help !!!
From my 79 trans am I remember the rear discs do
not clamp in. They must be rotated in the correct
direction to reset the parking brakes. From then on
I really appreciated rear drum brakes.
Old Sep 10, 2007 | 07:29 AM
1991LX5.0's Avatar
1991LX5.0
+1 i used to have a 96 and there was a special tool you need to spin the piston back in the caliper, it wasnt just a regular brake cube. I dont know if they changed the design from 96 to 01 though
Old Sep 10, 2007 | 10:02 AM
TwotoneVert's Avatar
TwotoneVert
Go to autozone and rent the correct tool. Dont buy that little 8 dollar socket tool either. Its a 35 dollar deposit and you get the tool that will spin and push the piston back into the bore. It has several different plates to fit your caliper piston. Also loosen the cap on the master cylinder to allow the fluid to push back. You get your deposit back from autozone when you return the tool.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
