idle point.
Old Feb 17, 2005 | 10:15 PM
98gtmustang's Avatar
98gtmustang
Default idle point.
my car is an auto and is idling around 1650-1700 rpms around 25-28mph... is it just me or does that seem a bit high...
Old Feb 18, 2005 | 02:01 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: idle point.
I don't get what you are trying to say....
Old Feb 18, 2005 | 06:37 AM
04GTPony's Avatar
04GTPony
that seems way high to me, mine is a stick but the idle should be the same, a motor is a motor...mine is about 800 rpms...although my coolent sensor went nutts a while back and made it idle that high for about a week before i reset it.
Old Feb 18, 2005 | 12:37 PM
roundman's Avatar
roundman
that is way too high an idle speed if you ask me. it should be no more than maybe 750 rpm or so in drive. check for a vacuum leak or loose/disconnected vacuum hose somewhere.
Old Feb 18, 2005 | 12:52 PM
artisan00's Avatar
artisan00
ORIGINAL: 98gtmustang
you mean the car is just moving that fast by itself when you are off the brakes?? thats scary
Old Feb 18, 2005 | 07:30 PM
propellerhead's Avatar
propellerhead
That's normal. If you're moving and pop it into neutral, the RPMs will hold high. You should be seeing around 700 in Park.
Old Feb 19, 2005 | 07:38 PM
98gtmustang
alright thanks everyone, im not talking about at a stop, i mean when im at about 25mph it is up that high... could it be because they reprogrammed my ecu?
Old Feb 20, 2005 | 12:35 AM
ZachW04Stang's Avatar
ZachW04Stang
Sounds like there making you run to rich at idle when "they" reprogrammed your ecu. By the way who is they, I'll make sure I don't order a chip from them.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
Sep 25, 2015 09:06 AM
