couple questions
Old Feb 28, 2005 | 03:04 PM
ByPopularDemand's Avatar
ByPopularDemand
Default couple questions
I have a 2000 v6 convertible the tires are perfectly ballanced and it gets shaky or vibrates at about 65 mph does anyone know what could be causing this also my friend has a 04 sentra ser spec v he has a cai in it and says he would smoke me i was wondering who you think will win
thank you any help will be much appreciated
Old Feb 28, 2005 | 06:01 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: couple questions
ORIGINAL: blackout
Is the shake coming from the steering wheel or do you feel it in your butt?
Steering wheel - is front end and could be a number of components. Easy test if it's on the front is lift each side or both on a jack. Grab the tire and push in on the right side while pulling out on the left and then do the opposite. Do this rapidly. If you notice any play, you've got bad bearings or tierods, or both.
In your butt is the rearend - you can do the same test but this will only test the bearings.
While you've got the car up take a look at the struts and shocks. You could be experiencing wheel hop. If you have a shock/strut that is leaky or just plain bad.
The other topic, The CAI doesn't do much with out other mods to take advantage of the added airflow. He does have a huge weight advantage on you.
Sentra SER Spec-V
Top speed : 135 mph
0-60 mph : 7.2 sec.
0-¼ mile : 15.6 sec @ 90.3 mph
60-0 braking distance : 120 ft
200 ft skidpad : 0.86 g
Curb Weight : 2743 lbs [&o]
Overall length : 177.5 in.
Wheelbase : 99.8 in.
Overall Width : 67.3 in.
Height : 55.5 in.
Mustang:
weight: 3240[:@]
it's hard to find the other specs but off a glance I'd say it would be close..If I rember correctly the 1/4 trap speed for the V6's are 15.5-15.7 at between 89-91mph...
Old Feb 28, 2005 | 06:04 PM
tightdogal's Avatar
tightdogal
My friend has a Sentra SE-R, theyre really quick. He has a stick but he has a cai headers and a new exhaust. He crushed me badly, needless to say in my 2000 6'er wit an auto and cai. so idk ud prolly lose those things are quick.
Tivo304
Aug 28, 2023 12:19 PM
1TUFF302
Nov 5, 2015 04:02 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
04stangman
Sep 17, 2015 01:45 PM
