Valve tap
Old Nov 4, 2007 | 09:32 PM
fearce65's Avatar
fearce65
Default Valve tap
Changed plugs and wires. Started car, loud valve tap. Checked the plugs and wires. Two plugs a little loose. All wires are in the correct spot. Started car, no valve tap for about 10 seconds, then started tapping again. Will check the gapping for the plugs for the 4th time tomorrow. Any other suggestions? Please help.
Old Nov 5, 2007 | 12:35 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Valve tap
I doubt you did anything to the valves with a plug/wire change. Likely just a plug issue. Make sure you tighten them to spec based on what the engine calls out. For the older 289's and similar iron headed engines, the spec is about 15lb-ft or so. Double check this with a manual, though.
Old Nov 5, 2007 | 03:57 AM
NJcobraEkul's Avatar
NJcobraEkul
make sure u check the spark plug gap in the manual. and measure the gaps before u reinstall
Old Nov 5, 2007 | 03:59 AM
NJcobraEkul
o yea make sure the plugs are to the correct coils. what year is the car?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
lmurf60
Sep 24, 2015 10:07 PM
