Auto Faster? Stick faster?
Old Mar 7, 2005 | 06:54 PM
  #141
Assassins's Avatar
Assassins
Default RE: Auto Faster? Stick faster?
umm, if you actually take the chip of the auto you can make it faster than the manually. But if it is stock vs stock, then I will probable go with manual. But also remeber if depends on the driver and if with Auto you want to start at 1 and move up yourself to 2 then 3 then D. (It does make a differenct.)
So, are you messing with the chips? And how are the drivers, a bad (newbie) shifter vs auto, I think Auto.
Old Mar 8, 2005 | 10:28 AM
  #142
kalicrates's Avatar
kalicrates
I think it depends on the driver in a manual... but if you have a good driver, the manual will win. It just allows for greater control and more accelaration rather than an auto. Most cars here in Britain are manual. I'd only have an auto if I had arthritus or something that made it painful to change gears.
Old Mar 17, 2005 | 09:38 PM
  #143
mark101's Avatar
mark101
well i have read several reviews and both state the auto and manual do 0-60 in 5.1 seconds for the new 2005 gts now as for older model cars and stuff and other model vehicles i dont no about which is better but from what i gave read the 05s manual or auto do it in same time
Old Mar 17, 2005 | 10:09 PM
  #144
ceyko's Avatar
ceyko
1. I own an '03 AODE.
2. I would get spanked by '03 5-speeds
3. I own a Diablo Predator.
4. I would still get spanked bya lot of '03 5-speeds, even with my shifts "tuned" to the max pressure and points with the Predator.
I feel confident that a "built" auto transmission could put a hurtin' to most 5-speed drivers. However, there will still be some out there that could pull off a better run.
Besides, aren't autos heavier too?
Take care,
Ceyko
Old Mar 17, 2005 | 10:24 PM
  #145
98gtmustang's Avatar
98gtmustang
i skipped 4 pages, what did i miss hahaha. i have an auto, and here is my opinion, auto's are more consistant, yes! but....if the person driving th manual knows what they are doing they should win. there is a greater power loss for the autos than the manuals... case closed. so basically mod ur auto or get owned by manual
Old Mar 18, 2005 | 12:27 AM
  #146
92stang's Avatar
92stang
I will prove you somthing Bud I have a 92 Mustang GT it was stock last summer it's a 5-spd. My friend had a 91 Mustang 5.0 Last summer it was stock it was a AOD Automatic if you cant catch that! and my car whipped the living S*** out of his auomatic yeah if they are built right they will win but stock for stock F*** A** a manual will tear ths S*** out of a automatic so your wrong just except it.
Old Mar 18, 2005 | 12:34 AM
  #147
ceyko's Avatar
ceyko
ORIGINAL: 92stang
Those are over ten years old...he will ding you on that. Still, it holds true these days too.
Old Mar 18, 2005 | 02:39 AM
  #148
92stang's Avatar
92stang
Yeah there over ten years old but still these days a manual would beat an automatic think about shift at higher rpms in a manual it doesnt have set shift points yeah if its a beefed a up auto i can see it but when it comes to stock a manual would win hands down simple as that.[sm=closed.gif]
Old Mar 18, 2005 | 04:53 AM
  #149
2kConvMustang's Avatar
2kConvMustang
Id say it all comes down to the driver, being that you could most likely launch the Standard harder then the Auto, but then shifting consistently come into play, but lets just say a person's that good to shift perfect everytime the standard won win. But there is drive error and the computer is the nearest thing to being perfect but nothings perfect not even the computer (the car would shift when it wants to shift the car does change its shift points to get the fastest ET)
Manual:
Advantage:
[ul][*] Shift were the car make the most power (or your able to just shift when you want to not when to car does)[*] being able to launch @ a higher RPM (you could launch @ say 3500 in a Manual vs. 3000 in an Auto)
[/ul]
Disadvantages:
[ul][*] Time it takes to shift (i.e. 1-2, and even with a short-throw an Auto shifts faster)[*] Inconsistincy (unless your good like some people are)
[/ul]
Auto:
Advantage:
[ul][*] Consistency (no matter what the an Auto will be more consistent)[*] Shifting is quicker
[/ul]
Disadvantages:
[ul][*] The car picks when to shift[*] Launch is lower that a Manual (unless you have a built up trans. but then it wouldn't be stock)
[/ul]
But like I said it depends on the driver heavily, but Id say the Auto because most people (or good drivers anyway) shift in their Auto's (1-Low, 2-High, D) so its like having the best of both worlds lol
but that's just what I think.
And every one has a right to their own opinion so if someone say's Manual but you think Auto's don't jump down there trouts its there opinion
Old Mar 19, 2005 | 09:28 PM
  #150
awnumber1's Avatar
awnumber1
this was the most pointless thread ever
