broken odometer
Old Nov 29, 2007 | 06:35 PM
mustang 1996's Avatar
mustang 1996
Default broken odometer
Is it a common thing for the odommeters to stop working because of a plastic gear?
and can I fix it without having to buy the whole thing at a salvage yard.
Old Nov 29, 2007 | 06:39 PM
Cryptostorm's Avatar
Cryptostorm
Default RE: broken odometer
you can fix it, but you have to tear apart your tranny... its not that complicated, and i would do it long before buying an entire new engine
Old Nov 29, 2007 | 06:45 PM
mustang 1996
I don't understand what this has to do with my motor and transmission.
Old Nov 29, 2007 | 06:53 PM
Cryptostorm
oh, my bad bro, i read that wrong...
Old Nov 29, 2007 | 10:24 PM
mustang 1996
I was hopeing to get alot more feedback then I did.
Very disapointed.
Old Nov 29, 2007 | 10:49 PM
ryan1994mustang's Avatar
ryan1994mustang
gotta give it a little time man...but if im not mistaken, both your speedometer and odometer work off of a little plastic gear that is located in your transmission. so if your speedometer is still working then it is probably something else.
Old Nov 30, 2007 | 01:09 AM
ponyponer's Avatar
ponyponer
i'd just leave it be. look at it this way. if your odometer stopped turning you won't have to worry about how many miles you're puttin on the car. a lot of people freak out over how many miles they got, and all that. as long as the other gauges work. i mean this could be a problem if you ever try to sell it though.
Old Nov 30, 2007 | 02:48 AM
89mustangfive0's Avatar
89mustangfive0
isn't there little speedometer gears behind the odometer as well? i know theres a speed sensor in your tranny that has little plastic gear as well. i know on my t-5 its on the drivers side of the tranny and a 8mm bolt holds it in see if its in correctly
Old Nov 30, 2007 | 02:04 PM
mustang 1996
Thanks to all that put in there input.
2007CalSpec
Dec 13, 2020 11:42 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
sammyd16
Aug 30, 2015 10:03 PM
Calizic
Aug 28, 2015 01:46 PM
