cut spring or remove isolator?
Old Mar 11, 2005 | 05:51 PM
lilnicky068's Avatar
lilnicky068
Default cut spring or remove isolator?
hey guys i just put in some lowering springs and it looked great!... untill i put my big stereo system in the trunk. that made the back drop lower than the front, and thats UGLY! so i want to drop the front some more. is it safe to cut the front springs? if not, is it safe to remove the isolators???
Old Mar 11, 2005 | 06:44 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: cut spring or remove isolator?
ORIGINAL: lilnicky068
I always cringe when people think it's okay to cut the springs...At least you asked! Don't cut the springs.
1) They have a specific compression rate they are rated/designed for. Cut them and you throw it out the window
2) It will screw up your alignment and ride/handling really bad
3) You will look like an old-school ricer with your body bouncing wildly as you go over bumps
If you pull the isolators, you could cause damage to your other suspension parts (Control Arms) those isolators take a beating.
My only suggestions are
A) Get a set of adjustable shocks like KYB that allow you to adjust the ride heigth.
B) Find a pair of lowering springs for the front that are lower than what you have in the back (i.e. rear is 1" front then is 1.25 or 1.5")
C) Go to Pep Boys and get a pair of shock spring clamps. Two clamps per side that basically go between the spring coils and can adjust the rear, up to increase the ride heigth. It will stiffen the rear up in the process too.
Those are my suggestions in order of preference.
Old Mar 11, 2005 | 06:48 PM
chriscindy6369's Avatar
chriscindy6369
Right on derf.
Just buy other springs.
Old Mar 12, 2005 | 10:25 PM
rsw007's Avatar
rsw007
put the stock springs back in back with stereo might be right hight now
Old Mar 13, 2005 | 04:11 AM
lilnicky068
im just going to get spring spacers for the back. i took the springs out yesterday and decided i probably shouldnt cut them.
Gene K
Oct 21, 2015 11:37 PM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
67LimeCoupe
Sep 21, 2015 06:34 PM
Sep 10, 2015 08:39 PM
vintageaion
Sep 8, 2015 10:45 AM
