oil won't drain?!
Old Mar 15, 2005 | 01:57 PM
SilverGTV8's Avatar
SilverGTV8
Default RE: oil won't drain?!
Oil presurre fluctates. Have you ever had a real oil pressure gauge? The factory ones on today's cars don't count.
I have driven several cars with real gauges. The porscha I drove on a regular basis had two guages. The oil pressure and a Druck press. One guage would go up one would go down. At idle the oil pressure guage will drop down and the Druck will go up. Under hard acceleration the two would switch.
Oil pressure dropping is not uncommon and occurs on every car out there. At idle the need for oil is less and the pressure needed to supply the oil is there.
But if the pressure really drops to a dangerous level like almost none then you have an issue.
Old Mar 15, 2005 | 02:10 PM
vfast's Avatar
vfast
I ♥ Acer
17..I wasn;t calling you out I was informing my peeps that people like yourself untrained work for jiffy lube
Old Mar 15, 2005 | 05:41 PM
fordguy17's Avatar
fordguy17
ORIGINAL: roundman
that's OK fordguy17, you weren't born knowing how to work on your car! suggest you buy a good quality repair manual on Mustangs and read up on things before you attempt to do any more maintenance on yours so you don't really do some damage next time!
yeah, i try to read as much as possible about car (forums, magazines etc.) but you don't really learn until you try it yourself. thanks for the help everyone.
Old Mar 15, 2005 | 06:47 PM
vfast's Avatar
vfast
I ♥ Acer
this is true but reading the right books will help you gain the knowledge so you can apply it....
Old Mar 16, 2005 | 03:44 PM
StangTangGT's Avatar
StangTangGT
yep i dint find the second one till about 3 changes in with my old 5.0.
Old Mar 16, 2005 | 04:20 PM
drumaz's Avatar
drumaz
I missed the 2nd plug on my first change too.. Think I screwed something up too.. Learned my lesson! I learn alot of things the hard way.. How to replace thermostat/waterneck gaskets, header gaskets, manifold gaskets...... lifters... pushrods,.. where to not buy product too.. Hot-rodding is fun.. I'm with ya Fordguy..
lincolnshibuya
Dec 8, 2015 04:37 PM
jerrytubes
Oct 23, 2015 12:11 PM
14gt_Track
Oct 1, 2015 02:47 PM
Sep 29, 2015 03:23 PM
wraith777
Sep 28, 2015 10:49 AM
