no thermostat?
Old Dec 18, 2007 | 09:34 AM
lewistk's Avatar
lewistk
Default RE: no thermostat?
thats a common problem! im there with ya!
Old Dec 18, 2007 | 10:08 PM
Colorado_Mustang's Avatar
Colorado_Mustang
I'm having a hard time with your "too much pressure in the radiator" issue. The radiator is supposed to be pressurized. Typically 14-15 psi. Higher performance engines will go higher. I run my '71 with a 20 psi cap. The pressure is what keeps the coolant from boiling.
Old Dec 18, 2007 | 11:40 PM
93_five_oh's Avatar
93_five_oh
ORIGINAL: Colorado_Mustang
umm... yeah that's what i was thinking. doesn't the cap determine how much pressure stays in the system?
and even if it was high, the pressure in the cylinder is a lot higher than in the rad. system. so the coolant/pressure is not going to force the gasket to break into the cylinder...
Old Dec 18, 2007 | 11:57 PM
02StanGT's Avatar
02StanGT
ORIGINAL: 93_five_oh
Not all the time. When piston is on it's way down during the intake stroke, it's pulling air in, therefore at a vacuum.This is less than coolant pressure. The cap is somewhat of a relief valve if you will. Will open andoverflow coolant/steam if you have too much pressure in the system.
Old Dec 20, 2007 | 12:37 AM
93_five_oh's Avatar
93_five_oh
but i wouldn't think for the split second it's creating a vacuum that it would suck the gasket in.
there's more cylinder pressure than there is vacuum and rad. pressure combined...
Old Dec 20, 2007 | 01:37 AM
02StanGT's Avatar
02StanGT
I guess I read your post wrong. I wasn't saying it would suck the gasket in. I was saying regardless of how the gasket breaks, it will still leak coolant into the cylinder.
Old Dec 20, 2007 | 01:46 PM
93_five_oh's Avatar
93_five_oh
oh.. i agree with ya there.
Old Dec 27, 2007 | 12:25 AM
kenv's Avatar
kenv
Actually, the engine may warm up, it will just take longer. If the engine is having overheating issues, removing the thermostat will make it worse. The thermostat also regulates flow so that the coolant has time to absorb the heat from the block/heads.
I agree^^
Nick Oliver
Oct 17, 2018 04:22 AM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Wesley1995
Aug 30, 2015 02:01 PM
