Forced Induction
Old Jan 1, 2008 | 01:48 PM
Whamo's Avatar
Whamo
Default RE: Forced Induction
ORIGINAL: jEEd
theoritically yes, but if you stomp on it , it wont.
+1 that,
when my procharger hits 12 or 13 psi @ about 5k rpm i bet i only get 4 or 5 mpg
also when ur crusin on the highways ur not boosting ur vaccuming which by the same mathmatics less air = less fuel but u still have parasitic load.
in anycase you shouldent sc or turbo ur car for gas milage.
Old Jan 1, 2008 | 09:24 PM
tbirdscwd's Avatar
tbirdscwd
It can increase gas mileage due to improved efficiencey, but most of it has to do with your tune and how you drive. My gas mileage on the freeway while cruising has improved by about 2mpg (I've seen similar results from others with a centri at ~same boost levels). However if your stomping on it all the time around town you will be lucky to see 10mpg.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
67LimeCoupe
Sep 30, 2015 04:46 PM
JDWalton
Sep 24, 2015 08:47 PM
jstrothe
Sep 24, 2015 12:17 PM
ccdguy
Sep 19, 2015 05:20 PM
