Sponsored by:
Sponsored by: DashLynx
What to use?? Door Trim
Old 01-01-2008, 08:18 PM
-SHIFTY-
-SHIFTY-'s Avatar
Default What to use?? Door Trim
One door on my 87 fox body is missing the trim. The door itself has a little leftover of whatever they used befor to keep it secure. I just wanted to know if anyone has had to put a door trim on, and what did you use.?. Never delt with body before, so new to me, thanks.
Also should I sand off the old adhesive before applying new, >? Help would be appreciated. Thanks
-SHIFTY- is offline
Old 01-01-2008, 08:37 PM
88Mach1
88Mach1's Avatar
Default RE: What to use?? Door Trim
they're held on with double sided tape. most auto parts stores should have it. it's used for moldings and emblems.
i don't know if you have to sand the old stuff off. you could probably just scrape it off and then use some goo gone or something.
88Mach1 is offline
Old 01-01-2008, 09:12 PM
-SHIFTY-
-SHIFTY-'s Avatar
Seems 3m double sided is the way to go, thanks man.
-SHIFTY- is offline
Old 01-01-2008, 09:22 PM
MU71L4710N
MU71L4710N's Avatar
i wouldnt use goo gone that stuffs real oily (the tape wont stick). you could use it but then you'd have to clean the oil off with alcohol. i'd just scrape it off and clean the residue off with alcohol
(anytime u put that tape on stuff u wanna clean the surface to get any oil or dirt off so the tape has a good place to stick to)
MU71L4710N is offline
jerrytubes
10-23-2015 12:11 PM
b8checker
10-08-2015 12:55 PM
mdg
10-01-2015 07:04 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: What to use?? Door Trim
