turn signal problem
Old Mar 23, 2005 | 04:51 PM
tdoehner's Avatar
tdoehner
Default turn signal problem
Hi, I've gotta 96 cobra and having a problem w/the turn signals. The 4 way flashers work fine. But the passenger side blinker goes hyper crazy and doesnt work. I replaced the bulbs and the light sockets w/no luck. I have a feeling it's in the wiring particularly near the turn signal lever because if I lightly push up on the lever the blinker works but if i push it all the way up to lock in the blinker it goes hyper, so I'm thinking the wire is getting pinched somehow when the lever is locked up (blinker on w/o holding the lever). Has anyone else experienced this? suggestions? Thanks guys.
Old Mar 23, 2005 | 05:12 PM
mikev08826's Avatar
mikev08826
I ♥ Acer
Default RE: turn signal problem
For what this is worth...Locate your turn signal indicator, what makes the tick when it's on, and replace that...that's my best suggestion.
Old Mar 23, 2005 | 06:22 PM
tdoehner's Avatar
tdoehner
i swapped out the flasher control unit on a fully functioning 95 mustang and put it in mine and that didnt work eithier
Old Mar 23, 2005 | 10:26 PM
roundman's Avatar
roundman
sound like the turn signal switch in the steering column is bad and needs to be replaced to me.
Old Mar 24, 2005 | 12:02 PM
Djs94stang's Avatar
Djs94stang
I agree with Roundman. Sounds like your turn signal switch is bad. It's an easy fix.
Old Mar 24, 2005 | 12:04 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
its a common problem, auto parts stores stock the turn signal switches
Nurdyguy
Jan 20, 2025 04:38 PM
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
iculookin
Sep 2, 2015 12:34 PM
