Cats...
Old Mar 24, 2005 | 03:31 AM
J M F O's Avatar
J M F O
Default Cats...
I've got a 01 stock GT, and I'm trying to figure out what will pass emissions for my exhaust. Where exactly are that catalytic converters on my car? Also, a buddy of mine told me that putting long tube headers on my car will probably make me fail emissions, is he right? And also how much of an effect will an off road mid pipe have as well? H or X. Thanks in advance.
Old Mar 24, 2005 | 10:32 AM
5.0mustang5speed's Avatar
5.0mustang5speed
I ♥ Acer
Default RE: Cats...
being that new of a car i think i would just leave it alone...a good cat only robs about 6-10 hp...a clogged one is where thewre is problems...not sure on the long tube
Old Mar 24, 2005 | 11:29 AM
Chopper's Avatar
Chopper
Default RE: Cats...
The cats are located just down from the exhaust manifold.You can see them by looking underneath the car where the exhaust comes down from the engine compartment.Long tube headers without cats might cause you to fail an emissions test,as will the off road pipe.This depends on the type of test.Some states only hook up to the diagnostic port of the ECM and look to see if there are any codes stored,others use a sniffer to check exhaust gasses.If your state hooks to the diag.port,then Malfunction Indicator Light eliminators(MIL'S)should keep the exhaust from throwing codes and you should pass emissions.Some will also do a visual inspection.The long tube headers and no cats will fail miserably in this case.There are good exhaust systems out there with cats and mid length headers that you can use although I don't know how strict your state's inspections are.If you have a shop that you can talk to,ask them what you can get away with.
Old Mar 24, 2005 | 11:37 AM
Djs94stang's Avatar
Djs94stang
Default RE: Cats...
The cats are located in the H-pipe. There are usually 2 pre-cats and 2 regular cats for a total of 4. A lot of aftermarket H-pipes with cats only have the two larger cats in a high flow design and are emissions legal. Probably this is your best bet.
Old Mar 24, 2005 | 04:04 PM
snlpa's Avatar
snlpa
Default RE: Cats...
ORIGINAL: Djs94stang
Cats are in the H-pipe....????
I have 4 cats and there not in the H-pipe on my 2002gt.
Old Mar 24, 2005 | 06:29 PM
J M F O's Avatar
J M F O
Default RE: Cats...
Can I do long tube headers with an off road pipe and still keep the cats? I don't really want to get rid of them. Or can I just do long tube headers and still keep the cats, and just go with a regular H or X pipe?
Old Mar 24, 2005 | 07:07 PM
Djs94stang's Avatar
Djs94stang
Default RE: Cats...
Really...well what pipe are they welded into?
Old Mar 25, 2005 | 12:20 AM
dan's Avatar
dan
Default RE: Cats...
Mobiusone stang
Aug 14, 2013 05:41 PM
Altay89
SVT Forums
Mar 15, 2013 10:40 AM
mtflyboy25
Tuner Central
Mar 1, 2011 12:14 PM
smitty2919
Aug 17, 2010 03:27 PM
Cal26Stang
Jul 7, 2010 11:37 PM
