Does disconnecting the battery erace codes?
Old Jan 28, 2008 | 02:01 AM
MustangMike2001's Avatar
MustangMike2001
Default Does disconnecting the battery erace codes?
I was having issues with running rich and I really need to find out what code was being thrown but I diconnected the battery and now it won't start at all. Will I still be able to read the old codes or are they lost?
Old Jan 28, 2008 | 10:18 AM
onesickstang01's Avatar
onesickstang01
Default RE: Does disconnecting the battery erace codes?
yes disconnecting the battery will erase codes(most of the time) once the car starts back up and runs it will usually sense the same problem and pull the code up again. since you cant start the car though that could be a big problem
Old Jan 28, 2008 | 11:04 AM
MustangMike2001
Well that sucks a big one.
Old Jan 28, 2008 | 12:59 PM
BLK89GT's Avatar
BLK89GT
have a friend push you down the street pop the clutch and head right to the zone and get them to read it. just a thought
Old Jan 28, 2008 | 01:41 PM
MustangMike2001
But I don't have any friends.. I'm kidding the car cranks fine it is just running so rich it's flooding out. Couldn't drive it down there if I wanted to.
Old Jan 28, 2008 | 02:14 PM
brad281's Avatar
brad281
It takes a while and usually a few runs before the code will come back on again. So going right to the zone won't do any good.
Old Jan 28, 2008 | 02:59 PM
MustangMike2001
Yeah I'm going to try to get it running tonight and see if I can get a code to pop up. See what happens then I guess.
Old Jan 28, 2008 | 03:30 PM
ewgoetz's Avatar
ewgoetz
It almost sounds like a issue I had with my ranger not to long ago. It turned out to be a PVC tube was cracked. Check for vacum leaks and make sure all the vacum and any other tubes are connect and not cracked or loose. I would even check out the pvc tubeing going from teh pcv valve and the tube that goes from the vavle cover to the intake tube.
PS
It was throwing codes of bad o2 sensors and runing rich.
Old Jan 28, 2008 | 04:44 PM
Ecstasy's Avatar
Ecstasy
uhh, that erases the codes on a 95 and under cars, i dont think it erases them on 96+ mustangs. i could be wrong though, but it didnt for a friend of mine.
Old Jan 29, 2008 | 12:34 AM
MustangMike2001
Yeah just checked for the codes tonight and there was none. Couldn't get it to run either. Oh well I have some ideas as to what is wrong it just would have been nice to have seen those codes.
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
ChampInSD
Oct 2, 2015 04:55 AM
