shaking
Old Jan 29, 2008 | 02:22 PM
oeys89stang's Avatar
oeys89stang
Default shaking
i drive an 89 lx with the 5.0. car shakes really bad above 60 and when i hit the brakes. i have had new tires put on and they are all balenced and i even had them balenced again and still same problem please help
Old Jan 29, 2008 | 04:47 PM
1991LX5.0's Avatar
1991LX5.0
Default RE: shaking
can you feel it in the steering wheel? I would look to see if your rotors are warped
Old Jan 29, 2008 | 05:14 PM
oeys89stang
Default RE: shaking
not really alot in the wheel.
Old Jan 29, 2008 | 06:43 PM
Chopper's Avatar
Chopper
Default RE: shaking
If it's in the front it could be worn front end parts like bushings or ball joints.
Rear end shakes could be the bushings or a driveshaft problem.Are the yoke bolts tight?
Can you duplicate the problem with the car on jackstands?
Old Jan 29, 2008 | 07:07 PM
zporta's Avatar
zporta
Default RE: shaking
had the same problem except it was in a truck and my rotors were warped so i would get them checked out...
Old Jan 30, 2008 | 10:27 AM
8barrell460's Avatar
8barrell460
Default RE: shaking
Most of the time when you get a vibration while braking it's in your brake system, and means most likely your rotors are warped. I have a lot of experience with this. I tend to be heavy on brakes, and always have been. Thats why my brake pads would only last me past 30k if I was lucky. I got tired of changing them so damn much that I would ride em, and my rotors would start to warp. If it's front end parts you feel the shaking or shimmy all times.
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Nov 18, 2015 01:34 PM
mdj89
Aug 31, 2015 07:27 AM
Careless00045
Aug 29, 2015 10:44 AM
