5.0 Speed dinsity
Old Feb 6, 2008 | 12:12 PM
orrisg's Avatar
orrisg
Default 5.0 Speed dinsity
I have a 5.0 speed dinsity and people tell me i cant put a cam or anything in it to make it faster is this true?
Old Feb 6, 2008 | 12:36 PM
btxlr8s's Avatar
btxlr8s
Default RE: 5.0 Speed dinsity
to a certain extent, yes. the sensor is built to measure between the range of a stock engine's Intake CFM, if you increase this CFM via either a cam, heads, or larger throttle body, the sensor will " peg out" and then your engine's A/F ratio will go lean at WOT. the solution to this is to either get larger injectors to " fool " the computer in to thinging it's putting less fuel than it acualy is, or a bigger MAP sensor and ECU flash. That's why its easier on newer cars with MAF sensors because they read what ever amount of air enters the engine, rather than whats suposed to enter the engine.
Old Feb 7, 2008 | 02:54 PM
Hawk's Avatar
Hawk
Certain cams are are speed density friendly. Just do your research before you buy anything. There are a couple of guys in the 5.0 forum running speed density with quite a few mods.
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
mungodrums
Sep 28, 2015 10:54 PM
vintageaion
Sep 8, 2015 10:45 AM
