help t5 no reverse
Old Feb 10, 2008 | 04:42 PM
Mikenindy1972's Avatar
Mikenindy1972
Default help t5 no reverse
I pulled wrong plug out of the side of the T5 tranny and lost reverse. I need tech on how to get into the linkage and fix said probelm. I here it is rather common all help is greatly appreciated
Mike
Old Feb 11, 2008 | 12:00 AM
Mikenindy1972
Default RE: help t5 no reverse
bump
Old Feb 13, 2008 | 07:51 PM
Mikenindy1972
bump
Old Feb 13, 2008 | 10:17 PM
mrdeep2001's Avatar
mrdeep2001
I dont know much about trannys, but I will try to help. What plug are you talking about?
Old Feb 14, 2008 | 01:49 PM
Tberg725's Avatar
Tberg725
That really doesnt make sence, the only two plugs that are on the T-5 are the fill plug and drain plug, both facing the passenger side. The fill plug is on top and the drain on the bottem....
Old Feb 14, 2008 | 08:27 PM
Mikenindy1972
Well it is not really a plug it is a bolt on the passenger side of the tranny. I have been told by a few people that it is a common mistake when and lube to the t5. like most peopl i pulled it out thinking it was the fill plug but instead it holds part of the linkage for reverse in place.now to fix said problem you have remove the top cover from the tranny and replace the link and reinstall the bolt. This is where I get stuck I have the tranny out of the car, and the bolts removed from the cover, but theLinkage from the shifterruns along the top of the tranny though the cover. the only fastener i can see hold the shift link is a roll pin in under the shifter cover it. Is there a way to remove the top of the tranny with out pulling all of the shift linkage out?
Mike
Old Feb 14, 2008 | 11:31 PM
Tberg725's Avatar
Tberg725
Anyway you can take a pic of the bolt you pulled out?
Old Feb 15, 2008 | 09:11 PM
Mikenindy1972
yes I take it tonight and upload it
Mike
Gene K
Oct 21, 2015 11:37 PM
foxdude
Sep 24, 2015 08:45 PM
maestro1024
Sep 21, 2015 02:40 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
