Grinding noise
Old Feb 13, 2008 | 01:10 PM
90coupe's Avatar
90coupe
Default Grinding noise
Need help bad! When I try to start the motor a nasty noise comes from the flywheel and starter area. Its an AOD, I put in a new starter and checked the flywheel and it looks to be in good condition. When I crank it it sounds as if its grinding, but dont now exactly from where?
Old Feb 13, 2008 | 01:15 PM
bacon57's Avatar
bacon57
Default RE: Grinding noise
I would check to see if you got the right starter.
Old Feb 13, 2008 | 01:54 PM
90coupe's Avatar
90coupe
I did, I took it off to check and I called to make sure it was the right one and they said it was.
Old Feb 13, 2008 | 11:19 PM
90coupe's Avatar
90coupe
Fixed the problem, I just shimed the starter and no more grinding!
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
ccdguy
Sep 19, 2015 05:20 PM
