Frozen bolts
Old Feb 17, 2008 | 06:50 PM
briansgonnawin's Avatar
briansgonnawin
Default Frozen bolts
eh im stuck again on my rear end. Anyone know the Tq rating for the drive shaft bolts or any tips on getting those Mf'ers out. i cant get them to budge at all, ive put liquid wrench on it like an hour ago...
Basically this exact pciture, which i just found.
Old Feb 17, 2008 | 07:45 PM
1991LX5.0's Avatar
1991LX5.0
Default RE: Frozen bolts
a smallblow torch is the easiest way their like $25, just heat the up a little and put a bar on your ratchet and give it a quick yank and it should come loose. And unless theirs a problem im missing all you do is rotate the DS to get to the other bolts. As for the torqu ratings im not too sure, i have a chiltons manual that i use for all my torque specs but dont have it here
edit: make sure you mark the position before you take the DS off
Old Feb 17, 2008 | 07:58 PM
briansgonnawin
thanks i will try the torch tomroow when i can get it. And yeah i can spin the drive shaft, that was just a picture i found which was pretty perfect for my purpose here
Old Feb 17, 2008 | 09:15 PM
BLK89GT's Avatar
BLK89GT
http://www.google.com/search?source=...g+torque+specs
google does wonders
Old Feb 18, 2008 | 05:57 AM
ewgoetz's Avatar
ewgoetz
Get some PB blaster instead of liquid wrench, spray and come back in 15 min and give it a try.
Old Feb 19, 2008 | 01:27 AM
Jfsram's Avatar
Jfsram
Your pinion seal may not be too happy about having a torch going there.
Rotate the bolt to the bottom. Jam the trans in 1st or reverse. Then take a box end 12 mm wrench and hammer the end of it. The impact action will get that bolt moving.
Old Feb 19, 2008 | 05:59 AM
corvetteguy's Avatar
corvetteguy
ORIGINAL: Jfsram
Liquid Wrench LIQUID WASTE......
Only use a HEX wrench
Use breaker bar if you don't
have an impact.
Old Feb 20, 2008 | 04:22 PM
ExtrmZ's Avatar
ExtrmZ
get an air ratchet
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
2poor4u2
Sep 26, 2015 11:08 AM
maestro1024
Sep 21, 2015 02:40 PM
trashxtrash
Sep 20, 2015 10:49 PM
