do explorer intakes have 65mm throtle bodys?
Old Apr 3, 2005 | 09:21 PM
philthy89fifty's Avatar
philthy89fifty
Default do explorer intakes have 65mm throtle bodys?
will an explorer intake bolt right up also do they have 65mm throttle bodys and if so will these bolt right up or will i have to change something?
Old Apr 3, 2005 | 11:21 PM
birdman076's Avatar
birdman076
Default RE: do explorer intakes have 65mm throtle bodys?
The upper intake will not bolt up to your factory upper, it is the same pattern as a cobra so you will need the lower as well. The TB is a 65 but need some linkage modifications to work. When looking for the Explorer set up, be careful that you don't grab one without EGR provisions unless you already removed the EGR. It will throw codes if there are no passages in the intake for EGR.
Old Apr 3, 2005 | 11:57 PM
philthy89fifty
will a 97 have egr? and what kind of modification will i have to do to the linkage?
Old Apr 4, 2005 | 12:35 AM
birdman076's Avatar
birdman076
Not sure, its easy enough to check, if there is a round hole in the middle of the lower or upper intake mounting flange then it has the EGR passage. The picture below is for a gasket for the Explorer or GT40 intake with EGR. Notice the small round hole in the center.
OSUTX440
Ohio Regional Chapter
Mar 15, 2021 09:27 AM
Luke9222
Oct 22, 2015 11:55 PM
Webster454
Sep 7, 2015 04:59 AM
Mustangmalo
Sep 6, 2015 05:22 PM
