is running 22 degrees timing bad?
Old Feb 25, 2008 | 10:05 PM
kennebellgt's Avatar
kennebellgt
Default is running 22 degrees timing bad?
I have a 95 gt 5.0 mods on my sig, and i stabbed my dizzy in and i know im on point with everything, lining 0 to the pointer (tdc) and did everything right, and the car runs like sh*t untill i turn up the timing past 10 dergees, and at 14 degrees the car runs good but has little power, i bump it up to 22 dergees and it burns through 1st and half way through 2nd gear im thinking my balancer may have spun? but i took the #1 plug out and got it to tdc ( right as the cylinder started going back down the 0 on the balancer was lined up with the pointer could it still be spun? im a little stumped here need advice thankyou My fellow mustang owners
Old Feb 25, 2008 | 10:49 PM
1991LX5.0's Avatar
1991LX5.0
Default RE: is running 22 degrees timing bad?
are you sure you stabbed the dizzy right? you should not be able to run 22 degrees BTDC without detonation
Old Feb 25, 2008 | 11:04 PM
kennebellgt
I put 0 on the balancer to the pointer at the right end, and i pointed to the #1 cylinder on the dizzy is this right? also no pinging..thanks for your input, i Love this site
ORIGINAL: 1991LX5.0
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
squishbang
Dec 4, 2015 02:29 PM
1987gt40ttopt
Aug 28, 2015 10:49 PM
mweiland
Aug 16, 2015 10:59 AM
