Overheating of 05 V6
Hi Everyone, I need some help, Please!!!!!!!!! My baby is an 05 V6, stock, well except for the dual exhaust and some body mods. Anyway, I had an alternator problem and my husband replaced it. Then 3 days later my car started to overheat. I never let it get into the red, would shut down, let cool then turn my heat on wide open and it would run semi hot. Had the thermostat replaced by a mechanic, now twice, still overheated, They then replaced a heat sensor, and now it's overheating again. They read my computer system and can't find anything there. Can one of you experts out there give me some good advise on what to check next?
Thanks very much,
Mustangpenny
Thanks very much,
Mustangpenny
RE: Overheating of 05 V6
Could be ...
low level of coolant or no coolant (check your coolant level)
plugged radiator or hoses
fluid leak (check for green fluid under engine)
fan not running
defective water pump
defective radiator cap
I'm wondering though since the alternator was recently replaced if maybe something got knocked loose or maybe even the belt was put on wrong?
fan not running
Thanks MustangMike2001 for the possible scenerios to my problem. The fluid level has been stable with no leaking detected. My mechanic said he checked the water pump and it was Ok, don't know how he checked, but I guess he should know if it's OK or not. But I don't think the radiator cap has been checked. That will be next on the agenda! I just hope we can figure this out. I love my car and this is just bumming me out. Thanks again!
Mustangpenny
Mustangpenny
Have you checked to see if the fan is running? If not drive the car till it heats up to or above normal temp. Then park it with it running and check under the hood. The fan should be on. I just don't see the cluster being the source of the problem but good luck with that.
ORIGINAL: MustangMike2001
When does it overheat. Idling, driving slow, driving fast?
Is your warranty expired?
mungodrums
09-29-2015 09:18 PM
yourmom6990
09-14-2015 10:52 PM
