coolant
Old Apr 4, 2005 | 04:32 PM
16FoxBody's Avatar
16FoxBody
Default coolant
theres a pool off coolant on the top of my block...why is that?
Old Apr 4, 2005 | 06:32 PM
pacepony's Avatar
pacepony
Default RE: coolant
check all your hoses and fittings. also check your thermostat housing. clean up the coolant and fill it back up and let it run to see if you can tell where it was coming from. also make sure you have a overflow tank. my pipe busted on mine and sprayed coolant all over my engine
Old Apr 4, 2005 | 06:37 PM
mustang4eva's Avatar
mustang4eva
Default RE: coolant
And never check coolant if engine is uber hot as it will spray all over you and car!
Old Apr 4, 2005 | 06:42 PM
pacepony's Avatar
pacepony
Default RE: coolant
and it will hurt
Old Apr 4, 2005 | 09:30 PM
luckypballer's Avatar
luckypballer
Default RE: coolant
very bad i learned the hard way(sheds tear)
Old Apr 4, 2005 | 10:39 PM
fordguy17's Avatar
fordguy17
Default RE: coolant
your intake manifold gasket could be leaking, but check all the other things first.
Old Apr 5, 2005 | 10:03 AM
Djs94stang's Avatar
Djs94stang
Default RE: coolant
Could you be more specific than "top of the block"?
Old Apr 5, 2005 | 01:44 PM
Texas 67's Avatar
Texas 67
Default RE: coolant
On top of the block at the front is most likely the thermostat housing or the bypass hose. The coolant temperature sensor is up there also (in the front of the intake I believe).
Old Apr 5, 2005 | 08:36 PM
Acer2428's Avatar
Acer2428
Site Mod
Default RE: coolant
First thing that popped into my head:
Cracked crossover on the intake manifold...
What year is the car?
edit: Saw your name as foxbody, if you have a fox, this is prob. not the case.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
Vrooom
Feb 21, 2016 05:25 PM
wraith777
Sep 28, 2015 10:49 AM
MusicCity615
Sep 12, 2015 07:05 AM
