95 mustang gt stock motor
I have a stock 95 gt that i would like to increase the hp on. BUT i would like to keep the factory heads and factory intake. The only mods i have at this point is headman hedder O/R H pipe with borla 2 chamber muffers. I even keep the stock tips. What things can i do?
RE: 95 mustang gt stock motor
Bigger throttle body?
If the air intake is stock then stick a K&N filter in it so it breathes easier, or get a full CAI if you want to improve bling at the same time.
If you want a JOLT of extra power but want tokeep the heads/intake stock then just add naawwwzzzzz. Remember though it's illegal to use on the street [&:]
i was thinking in terms of gears, maf, throttle body, injectors, cam, 1.7 roller, and possibly a supercharger. Would this be to much for the factory heads and intake. I do realize that it would be a bottle neck but what is the potential hp with or without a supercharger and these mods?
why are you trying to keep the stock heads and intake if you are gonna mod it that much? especially if you are going to change out the cam and rollers. that just doesnt make sense as to why you wouldnt go ahead and change out the heads while you are there. or if you are dead set on keeping them, at least have them ported for a little better flow. a blower on that setup would produce decent power, but with more airflow would produce tons more power than the stock heads/intake.
ORIGINAL: birdogg6482
i think that i am going to add a supercharger. So i can get the hp increase that i want then just add parts later. is there a supercharger kit that anyone would recommend?
With the stock manifold and heads, there isn't MUCH you can do that will offer a decent jump in hp.....
Things that won't increase horsepower, but put power to better use are: 4.10 gears, short throw shifter(if manual),sticky tires, etc etc etc.
yea man tires, cai, headers, throttle body, maf, short throw, stuff liek that, u have to do boltons first then a blower, not just threow a blower on there, u gotta build ur mottor a lil better so it gets sued tot he boost, but kenne bell or paxton
