rear caliper question
Old Apr 11, 2008 | 12:47 PM
Stimmel's Avatar
Stimmel
Default rear caliper question
I have a 88 turbo coupe rear end in my car with about 60 miles on it now, everyhting was fine until i drove it a few days ago and noticed a smell and got out and saw some smoke comming from the driver side rear caliper...not good....the car has all new hard lines and russel stainless lines all around, did napa just give me a bad caliper and i should replace it or what do you guys think is going on...?
Thanks
Old Apr 11, 2008 | 05:52 PM
andysm's Avatar
andysm
Default RE: rear caliper question
Had the same problem with an older modle. I had a caliper stick, replaced it just to have it stick again immediately. I called the local autozone and got after them, and they asked me to make sure it was stuck and then snap the bleeder valve open. If it squirted brake fluid everywhere, then the brake hose is bad. Guess what? He was right. It seems the inner liners of the brake hoses come apart and work as a trap door, as to not allow the fluid to return tward the master cylinder. Try it out, and see if it is the problem. The only thing that really sucks isa hose costs near as much as a caliper.
Old Apr 11, 2008 | 06:08 PM
Stimmel's Avatar
Stimmel
thanks ill try that dont think thats the problem tho, i have brand new russel stainless steel hoses on the car all around
Old Apr 11, 2008 | 06:17 PM
andysm's Avatar
andysm
ORIGINAL: Stimmel
They may have got some fluid and sh-- on you rotors. Might eventually burn off, or use a brake/caliper cleaner. You will most definitely know if one sticks, there is no doubt about it.
Old Apr 11, 2008 | 08:03 PM
Stimmel's Avatar
Stimmel
replaced the caliper same problem.....all lines are new and its only that one caliper
Tivo304
Aug 28, 2023 12:19 PM
musnicki
Sep 23, 2015 07:11 AM
Dragonus18
Sep 9, 2015 01:21 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
