tires
Old Apr 12, 2008 | 08:52 PM
jcamp2003's Avatar
jcamp2003
Default tires
I have 17x8 rims with 245/45/r17 whats the biggest tie I can go with on my 2001 cobra
Old Apr 13, 2008 | 12:48 AM
OnyxCobra's Avatar
OnyxCobra
Default RE: tires
245 is the correct width for an 8" rim, if you want to run a wider tire then you should buy wider wheels. People run 10 or 10.5" rims with 315 tires on 94-04 Mustangs without much problem.
Old Apr 13, 2008 | 07:56 AM
tbiker99's Avatar
tbiker99
Default RE: tires
I have a 2004 GT with the polished 8" wheels that the 01 Cobra's had. I have 275/40s (fuzion ZRi) on all four corners, and they look good. All tire manufactures will say that the tire is too big for the wheel, and I wouldn't say they are wrong. 275s are supposed to be mounted on a 9-11" rim. But they will fit, if your local shop will mount them, somewon't for liability reasons.
The ZRis are a bit smaller then some of the other 275s, and they have a "rim guard" that keeps the tire from looking funny when mounted on a smaller rim.
good luck.
Old Apr 13, 2008 | 09:02 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: tires
275s definitely fit and don't look bad (i'm running them on the rear) but they don't wear perfectly as the inside wears faster.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
