spark plug wires
Old Apr 17, 2005 | 09:49 PM
kwikstang's Avatar
kwikstang
Default spark plug wires
i wanted to put in a new set of plug wires but was wondering what brand to buy. i've seen the ford ones for only $45 but the accel wires for $105. i even found an auction for magnecor wires going for $145. magnecor 8.5mm spark plug wires wtf, i just saw a set of nology wires for $275. why are they so different in prices? any other brands to consider?
Old Apr 17, 2005 | 10:11 PM
sastangman's Avatar
sastangman
Default RE: spark plug wires
i have accel. you could try msd, or taylor..
Old Apr 17, 2005 | 11:08 PM
vfast's Avatar
vfast
I ♥ Acer
get the set with the lowest ohm resit in the wire..those ford's are not it a good low ohms wire can be had for arond 75.00...look at msd
Old Apr 18, 2005 | 05:43 AM
kwikstang's Avatar
kwikstang
ok. i've narrowed it down to taylor, msd, or nology. any preferences? nology wires cost about $300 with an advertised 2-5% hp gain, increased torque and better acceleration.
Old Apr 18, 2005 | 03:20 PM
Deannostang's Avatar
Deannostang
Watch out what the manufacturer's claim on power gains. Many times their tests are done on Cobra's which start out life with a whole lot more stock HP and torque. Still, a good set of wires is piece of mind that all your cranking horses get through to your wheels. Also check out the condition of your coil(s) to be sure they are up to snuff as well. A coil breakdown can cause all kinds of nasty stuff at certain rpm's. I used to have a '91 Cougar XR7 with a 5.0 HO that I installed Ford Racing wires on almost immediately. Had the car a long time after that and ignition was never an issue. Also had the Mallory coil as well.
Unless I was dragging my car regularly and trying to get every 100th of a second out of her, I don't think I would spend $300 for wires. However, check out these cool new plugs on the market.....and only $5.99 each!
http://www.e3sparkplugs.com/techoverview.asp
Good luck with your ride!
Old Apr 18, 2005 | 03:27 PM
Fallstar01's Avatar
Fallstar01
what year car do you have?
Old Apr 19, 2005 | 05:12 AM
kwikstang's Avatar
kwikstang
it's a 96 gt.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
