Changing U-Joints
Old Apr 19, 2005 | 08:32 PM
Aliate X's Avatar
Aliate X
I ♥ Acer
Default Changing U-Joints
Do you need that tool they say you need in chilton book to do U joints?
Old Apr 19, 2005 | 10:31 PM
fats429's Avatar
fats429
Default RE: Changing U-Joints
are they talking about a ball joint / U joint press NO you dont need that
You do need a heavy bench vice . the U joint nhas 4 clips holding it in , the two you see threw the yoke use a neaddle nose plires to get them out . then thare is 2 C clips on the inside of the U joint behind the yoke .
after they are off get a small socket to fit on the yoke to push the u joint out and a big socket on the other side to let the u joint fall into that . put the sockets on the u joint and lock them up in the vice and press them out
you might need a pipe on the vice handle . and it will get bent up if they are oringal U joints from the factory cause the use this injected plastic **** and is tuff to get out
Old Apr 19, 2005 | 10:54 PM
vfast's Avatar
vfast
I ♥ Acer
or you can use a socket and a hammer
Old Apr 20, 2005 | 02:44 PM
Djs94stang's Avatar
Djs94stang
I only use a socket and vise.
Old Apr 20, 2005 | 03:20 PM
Aliate X's Avatar
Aliate X
I ♥ Acer
alright ill let ya guys know how it turns out. thanks.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
lmurf60
Sep 24, 2015 10:07 PM
